How to create or remove Cinematics
Editor → Tools (Ribbon tab) → Cinematics (Ribbon bar)
When you create a new cinematic, it will serve as an "empty slot". Before a cinematic can be used, it is important to add key points to the cinematic, and to adjust their location.
The left panel allows you to select cinematics.
How to create a new cinematic:
  1. Select "Visuals" in the ribbon header.
  2. Select "Cinematics" in the ribbon bar.
  3. Select "Add cinematic" in the left panel.
How to duplicate an existing cinematic:
  3. Select the existing cinematic you wish to duplicate.
  4. Select "Duplicate" in the left panel.
How to remove an existing cinematic:
  3. Select the cinematic you wish to remove.
  4. Select "Remove" in the left panel.
How to's
