Subsidence Overlay
Result types
The overlay offers the following result types:
Result type Unit Description
SUBSIDENCE m change in land height The amount that the ground has lowered as a result of subsidence, both oxidation and compaction. A positive number means the ground has lowered.
OXIDATION m change in land height The amount that the ground has lowered as a result of peat oxidation.
SETTLEMENT m change in land height The amount that the ground has lowered as a result of compaction.
HI_GROUND_WATER m distance from surface to ground water The distance between the ground surface and the highest ground water level. This number is lower than that of the lowest ground water level. A positive value means the ground water is below the surface of the land. A negative value would theoretically mean the ground water has risen above the surface of the ground.
LOW_GROUND_WATER m distance from surface to ground water The distance between the ground surface and the lowest ground water level. This number is higher than that of the highest ground water level. A positive value means the ground water is below the surface of the land. A negative value would theoretically mean the ground water has risen above the surface of the ground.
Taken into account are:
  • soil temperatures in comparison with crop growth calendar;
  • plowing difficulty for a soil and season;
  • sowing problems for the given water levels, crop and soil;
  • germination problems due to sub-optimal water concentrations in the soil;
  • harvest issues due to not fully grown crops;
  • sub-optimal conditions for grassland growth;
|- | DAMAGE_SALT | % loss of earnings | The loss of agricultural earnings due to salt water irrigation or salt water seepage, for a particular crop, using the highest and lowest ground water levels adjusted by subsidence. These earnings are calculated by the Waterwijzer Landbouw api. Too much salt concentration leads to a reduction of water absorption of plant roots, increased toxicity, problems with nutrients absorption and decreased root growth. |- | DAMAGE_TOTAL | % loss of earnings | The total loss of agricultural earnings for a particular crop, using the highest and lowest ground water levels adjusted by subsidence. These earnings are calculated by the Waterwijzer Landbouw api. |}
Legend
The legend of the subsidence overlays is automatically calculated, based on the amount of years being calculated by the overlay. The colors will remain constant based on average subsidence per year. I.e. if the amount of years is doubled, the values in the legend, corresponding to specific colors, are doubled as well. Because the legend displays total amounts of subsidence rather than averages, the displayed range of amounts changes when the amount of calculation years changes.
The legend of the ground water overlays is constant, and will display a color from blue through yellow to red to indicate how wet the soil is. The closer the ground water is to the surface of the land, the bluer the overlay. In contrast to the subsidence legends, the range of values for ground water do not change.
Output
The output of all result types of the overlay is in meters. The results can be exported as GeoTiff.
Subsidence output
The output of the grid of each subsidence result type is the subsidence in meters. Depending on the exact result type used, the output is the amount of subsidence as the result of one specific calculation, or the sum of all the calculations of subsidence.
The hover panel will display the following information:
  • The amount of subsidence taking place over the configured amount of years.
  • The current surface water level, and to what level it will have changed after the subsidence has taken place.
  • The indexation policy currently configured for this water level area.
Ground water level output
The output of the grid of each ground water result type is the final distance from the ground water level to the surface of the land in meters.
  • The level to which the ground water will have changed, after the subsidence has taken place.
Final water level
The overlay can also write the final surface water level to an attribute of an area. The area where the attribute will be written to is the area which has provided the original water level for the overlay.
