How to couple Cinematics to Stakeholders
If desirable, it is possible to attach a cinematic to a stakeholder for a specific scenarios. This means that when the scenario is activated, the user in the role of that stakeholder will see the provided cinematic. A cinematic can be viewed by multiple stakeholders, at the same time or at different moments for each.
How to couple a cinematic to a stakeholder:
- Open the scenarios editing panel in the multi scenario ribbon.
- Select the scenario in which you want to show a stakeholder a cinematic.
- Select the "Stakeholders" sub-item.
- Select the stakeholder to whom you wish to show the cinematic.
- In the right panel, make sure the "Start with Cinematic" checkbox is checked.
- Using the dropdown below the checkbox, select the cinematic you wish to show.
How to's
- How to create an HD Movie or Video Recording from the cinematic
- How to create or remove Cinematics
- How to edit Cinematics
- How to edit Key Points
- How to edit the Camera Position
