Weir dam output (Water Overlay)
Revision as of 15:33, 14 November 2025 by Frank@tygron.nl (talk | contribs) (Created page with "{{overlay keys|<onlyinclude> {{overlay keys|type=row|group=Water Overlay |key=OBJECT_WEIR_DAM_OUTPUT |unit=m |description=An array of values, each value indicating the width that the object had at the time of the timeframe recording. |defaultvalue=None |icon= |range=-{{max surface}} to {{max surface}} }}</onlyinclude>}} This attribute is automatically created for all breaches in a project when a Water Overlay|water calcul...")
This attribute is automatically created for all breaches in a project when a water calculation is performed. When the calculation is complete, the attribute is updated automatically.
  • This attribute does not need to be created when configuring the project. This attribute is created automatically by the Water Overlay when a calculation is performed.
  • Each Water Overlay will create this attribute with the ID of an Overlay appended to it, to prevent the results of multiple Water Overlays storing their results in the same attribute by default.
