GeoTIFF Overlay
A GeoTIFF Overlay, where the data of a GeoTIFF is displayed.
The GeoTIFF Overlay is a Grid overlay which displays the values of a selected GeoTIFF in the project area. It is commonly used to display raster data imported into the Project from outside the Tygron Platform.
When clicking on a specific location in the map of the GeoTIFF Overlay, the hover panel gives additional information over the actual value in that specific grid cell. That value will be an interpolation, determined by the translation between the source file's resolution and the grid cell size.
GeoTIFF sources
The GeoTIFF Overlay can show GeoTIFFs which are uploaded to the Project as an asset and data of that asset is stored as a GeoTIFF item. Any number of GeoTIFFs can be added to a GeoTIFF Overlay, with each GeoTIFF defining an individual timeframe in the GeoTIFF Overlay.
Color RGB
By default the first band (or channel) in a GeoTIFF is selected resulting in a 32-bit result of for example a height map.
It is however also possible to select a different band via the BAND attribute. This way you can also load in a Aerial[1] color image. Start by creating 3 GeoTiff Overlays for the R channel (BAND=0), G channel (BAND=1) and B channel (BAND=2), then combine these in a Combo Overlay via the COLOR(R,G,B) formula. The result will show a color image.
