Net edit
Net edit is an option in the editor that allows users to add, remove or replace Net Lines for networks using special drawing tools. These drawing tools are different from the usual selection drawing tools (brush).
Draw modes
- Add
- Add a Net Line consecutively by adding net nodes and connecting the newest node with the previous one by adding a net line between them. Click on the same spot to stop the consecutive adding and to start somewhere else.
- Inserting a node into an existing Net Line is also possible. Snap distance is controller using the Merge distance (m) value.
- Connect via roads will create a path from start to end using the road system.
- Remove
- Select a net line to remove, highlighted in red. With the option repeated selected, more net lines will removed until a net node is encountered that is connected to more than one other net line.
- Move
Draw options
There are some additional draw options for editing networks.
Connect via roads
This option is used when in the Add draw mode. It will add multiple Net Lines following the road to connect the start and end point when adding Net Nodes.
The two Net Nodes to create a path for.
Repeated
This option is used when removing Net Lines or Net Nodes. The original Net item will always be removed, but additional Net Nodes can be removed as well, as long as those Net Nodes are only connected to one Net Line.
Remove a Net Line of an existing network. Only one will be removed, because it immediately encounters a junction.
Remove a second Net Line. More will be removed until a junction is encountered.
Remove a third Net Line. Now the whole network is removed.
