Grid Overlay
A Grid Overlay is a calculated overlay. It uses a 2-dimensional grid for calculation, data storage and visualization. The calculation divides the entire project into a grid of equally sized square cells, with possible size per cell ranging from 0.01m² up to 100m², depending on the size of the project area. This amounts to anywhere from thousands to millions of cells per overlay.
Calculations
- Net Lines
- Addresses and Buildings
- Terrains
- Areas
- Neighborhoods
- Plots (Only for Ownership Grid Overlay)
With all the data obtained, a new values or set of values is calculated for the cell, and stored as result data for that cell. The calculation may specify this processing repeating a large number of times, for example when iterating through time steps.
There are also several generic attributes that can be used to guide the calculation of all Grid based overlays:
| File:Iteration acvtive.png | ITERATION_ACTIVE | number | -1 to 1000 | Determines in which iteration the overlay will be calculated | -1 (all iterations) |
| File:Iteration acvtive.png | SKIP_NO_DATA | boolean | When value is 1 NO_DATA values are skipped when updating the model result to the grid overlay contents. | 0 (ignored) | |
| File:Gpu cluster index.png | GPU_CLUSTER_INDEX | number | -1 to inf | Select a specific GPU cluster to run the grid overlay on. | -1 (ignored, select best available) |
Using grid results
The results of a grid overlay calculation can be used in multiple ways.
Visualization
The legend displayed while the overlay is active can be configured to fit the magnitude and intent of the colors of the overlay.
The overlay grid textures are obtained as images from the WMS endpoint of a session. A style parameter defined by the Grid Overlay's Result Type determines the way the Grid Data is drawn as an image.
The following styles can be used:
| Style | Description |
| INTERPOLATED | The default style for most Grid Overlay result types. |
| NEAREST | Used for descriptive result types that should not be interpolated. For example: base types results, ownership, destinations and areas. |
| ARROW | Used for directional result types. |
| COLOR | Used for the WMS Color result. |
| FLOAT32 | Provides numerical data. Usable by WMS Overlays as numerical input. |
| DIFFERENCE | An additional style which visualizes a comparison between the CURRENT and MAQUETTE result of a Grid Overlay. The difference legend instead of the normal legend will be used for colorization. |
TQL
Export
The results can also be obtained by using the WMS endpoint of a project session. See also Visualization for the allowed styles.
Save
Grid recalculation
Some overlays could be a delaying factor in the project. For more information see the troubleshooting page.
See also: How to force Grid Overlays to recalculate.
Delayed calculation
During business hours (9-17, GMT+1, during weekdays), there is a maximum calculation time of 0.5 hour. If a calculation takes longer than that, it will time out after 1 hour. Outside of business hours, calculations will not time out. If necessary, it is possible to postpone the recalculation of overlays until after business hours.
See also: How to delay Grid Overlay calculations.
Settings
Grid size
The maximum amount of cells any given overlay or result type can have is 1 billion individual cells. For any given overlay, this includes the results of all timeframes of that overlay. Per project it is possible to have an Overlay with result types where the maximum amount of grid cells is 2 billion for the Overlay and the result types in total. You can have multiple Overlays + result type groups in your project. For example a Flooding Overlay with result types (max 2 billion grid cells) and also a Heat Overlay with result types (also max 2 billion grid cells). You can then for example add the Rainfall Overlay with result types (also max 2 billion grid cells) etc.
Note: if you select a grid size which does not neatly divide your project size, the south- and eastern edges of the project may not be covered by the grid, and not taken into account during a calculation.
Grid Accuracy Threshold
As the grid size decreases (and thus more cells exist in the project), calculations will take longer to complete. Under normal circumstances, when a calculation is based on geographical parameters, all contents of the cell are checked and all objects relevant to the calculation are taken into consideration based on how much of the cell is covered by it. When the grid size falls below this threshold, the method for determining these parameters changes. Instead, the exact center of the cell is checked, and if relevant data is found it is taken into consideration as if it were present in the entire cell. This is less accurate, but allows the calculation to complete faster.
Individual settings
Each individual grid overlay also has a few settings which can be set per grid overlay. These settings should be tweaked based on the actual meaning, intent, and impact, of the displayed results.
Active
Whether the grid overlay is active or not. When an overlay is inactive, the output of the overlay is not recalculated when an update or recalculation takes place. This means the results calculated by a grid overlay can be stored and inspected in a project without the computational overhead of performing the underlying calculation anew. This also means that the overlay's output may not represent the most recent evaluation of the state of the project. Instead, this option can be used to create results based on multiple scenarios, and to compare those to one another or to calculations which are updated along with changes in the project.
See also: How to set an Overlay to active or inactive.
Legend
See also: How to configure a Grid Overlay's legend.
Difference option
Depending on the actions an end-user can take during a session, the difference between two states of a calculated overlay may not be directly visible. To help gain insight into the differences in the results of grid calculations, a grid overlay may be given the option to inspect the difference in results between the original and planned situation. This means the end-user can activate a variant of the overlay which shows the amount of change between the original values, and the values resulting from the planned actions. This is effectively a separate grid with its own values, based on the actual calculation. The difference overlay can be further configured with its own legend. The difference result calculation is performed server side by providing the DIFFERENCE style when requesting a grid overlay image.
See also: How to enable the difference option for a Grid Overlay.
- The maximum amount of grid cells in a Project is also dependant on the license in which the Project is used, as well as the size of the Project's extent.
- How to adjust a project's Grid Settings
- How to force Grid Overlays to recalculate
- How to delay Grid Overlay calculations
- How to configure a Grid Overlay's legend
- How to enable the difference option for a Grid Overlay
- How to use the Overlay Overview
- How to set an Overlay to active or inactive
- How to sort Overlays
- How to export a Grid Overlay as GeoJSON
- How to export a Grid Overlay as GeoTIFF
- How to export a Grid Overlay as ASCII
- How to export a Grid Overlay as png
- How to export a Grid Overlay to the GeoShare
- How to smooth Grid Overlay results
- How to fill NO DATA values in a grid overlay by interpolation using and Average Overlay
- How to create an Average Overlay based on another Grid Overlay
- How to create an overlay for visualizing your own geographical vector information
- How to create an Average Overlay based on feature attributes
- How to configure an Average Overlay to gain insight into grid cell values
- How to create a traffic density Grid Overlay
- How to make a Grid Overlay of residence walls
- How to make a Grid Overlay of residences
- How to use a Grid Overlay to change the elevation model
- How to configure the Distance Zone Overlay to count features
