Left Panel
Revision as of 10:52, 1 February 2024 by Frank@tygron.nl (talk | contribs) (Select a filter)
The left panel, on the left side of the screen, provides access to sub-items and functionality of the item currently selected on the ribbon bar. For example, when the indicators button is currently selected on the ribbon bar, access to the current active indicators in the project is available.
The Tygron Editor. The Ribbon at the top of the screen, the Left Panel on the left side of the screen, the User Main Interface in the center of the screen, the Right Panel on the right side of the screen, and the Bottom Panel at the bottom of the screen.
Left panel overview
The left panel allows you to select, add and remove items.
This example shows the left panel when the indicators button is selected in the ribbon
Search and Select a filter
Filter options
The left panel starts with a search field, useful for lists with a lot of items.
Most Left Panels have additional filters to select. These are dependent on the type of Item. Examples of what you can filter on are:
  • Stakeholder, with specifying the particular Stakeholder related to that item.
  • With Attribute (has Attribute), with a button to select a particular existing Attribute and a field that displays the selected Attribute.
  • With Attribute (non zero Value), with a button to select a particular existing Attribute and a field that displays the selected Attribute. The item should have a non zero value for that attribute.
  • Category; Building should be of a particular Category.
  • Function; Building should be of a particular Function.
Items
Item-list
The left panel features different context-senstitive items. Selecting one of the items makes the properties available of the selected item. Its properties can be adjusted in the right panel.
Adding and removing Items
Adding, Removing and duplicating Items
The bottom of the left panel provides access to adding and removing items (in this case indicators).
