Category:How-to's
Revision as of 12:48, 15 June 2020 by Rudolf@tygron.nl (talk | contribs)
- How to (de)activate a Neighborhood per Scenario
- How to Georeference a 3D model
- How to access the 3D Tiles endpoint of a session
- How to access your project's WFS in ArcGIS Pro
- How to access your project's WFS in ArcMap
- How to access your project's WFS in QGIS
- How to access your project's web endpoints
- How to access your project data in Power BI
- How to activate the correct videocard
- How to add, remove and duplicate
- How to add, remove and duplicate a Neighborhood
- How to add, remove and duplicate an Indicator
- How to add Financial Actions to your project
- How to add Functions for editing
- How to add Subsidence (Water Overlay)
- How to add a Category to a Function
- How to add a Cinematic to the 3D Web Viewer
- How to add a Disclaimer to a Template Project
- How to add a GeoTIFF to a measure
- How to add a Levee Spatial to a Measure
- How to add a Levee Type to an Action Menu
- How to add a Measure to the 3D Web Viewer
- How to add a Panel
- How to add a Panel which can be opened from an Action Menu
- How to add a Satellite Overlay
- How to add a Template Panel
- How to add a User
- How to add a WFS link to your project
- How to add a WMS as an WMS Overlay
- How to add a breach level area to a breach
- How to add a breach with external area manually
- How to add a breach with input area manually
- How to add a dynamic traffic model
- How to add a limitation area
- How to add a spatial Panel
- How to add a static grid-based traffic model
- How to add a static traffic model
- How to add a timeframe for initial conditions of a simulation (Water Overlay)
- How to add an Answer to a Panel
- How to add an Area
- How to add an Area to a Measure
- How to add an Attribute
- How to add an Attribute Action to your project
- How to add an Attribute to a Function
- How to add an Event to an Answer of a Panel
- How to add an Inference Overlay
- How to add an address
- How to add and activate a traffic unit
- How to add and configure hydraulic structures (Water Overlay)
- How to add and remove Event Bundles
- How to add and remove Globals
- How to add and remove Net Loads
- How to add and remove a Result type
- How to add and remove a Zone
- How to add and remove actions
- How to add and remove an Area
- How to add and remove an Attribute
- How to add and remove an action menu
- How to add and remove buildings
- How to add and remove measures
- How to add data to a pre-existing GeoShare Viewer
- How to add or remove a Scenario
- How to add or remove upgrade types
- How to add rain barrels to your project
- How to add sewer data (Water Overlay)
- How to add terrain changes to a measure from a DXF file
- How to add the Aerius Overlay
- How to add the Travel Distance Overlay
- How to add the Waterwijzer Overlay
- How to add traffic data unaligned with roads
- How to add your own Overlay Icon
- How to add your project's WMS in ArcGIS Pro
- How to add your project's WMS in ArcMap
- How to add your project's WMS in QGIS
- How to adjust Building Costs
- How to adjust Buyout costs
- How to adjust Demolition Costs
- How to adjust Income generated by constructing
- How to adjust Land Price when buying
- How to adjust Land price when selling
- How to adjust a project's Grid Settings
- How to adjust the amount of Transferred Money
- How to adjust the foliage height and crown factor
- How to adjust the height map with a Combo Overlay
- How to adjust the starting budget of a Stakeholder
- How to apply fixes for multiple components in the Water Overlay Wizard
- How to assign a Panel to a specific Stakeholder
- How to assign ownership based on Online GIS data
- How to automatically import WFS Areas for a new Project
- How to automatically import WFS Buildings for a new Project
- How to automatically match AutoCAD Layers to Buildings
- How to base a new Project on a Template Project
- How to calculate the daily average radiation
- How to calculate the daily average wind speed
- How to calculate the daily min and max temperature
- How to calculate the hourly humidity
- How to calculate the hourly radiation
- How to calculate the hourly wind direction
- How to calculate the hourly wind speed
- How to change Attributes for a Function
- How to change Events fired by a Scenario
- How to change Function Values for a Function
- How to change Measures activated by a Scenario
- How to change individual ownership
- How to change multiple Attributes at once for Water Overlays
- How to change ownership for an area
- How to change properties of a Scenario
- How to change properties of a traffic unit
- How to change the Category of a Function
- How to change the ground price
- How to change upgrade type properties
- How to change where recorded videos are stored
- How to check for errors when using the net validation panel
- How to check for errors when using the network wizard
- How to combine GeoTIFFs on the Geoshare into a single Grid Overlay using WMS Overlays
- How to combine results of multiple Overlays as timeframes in a Combo Overlay
- How to compute additional shadow effects for the Heat Stress Overlay
- How to compute cool locations of sufficient size
- How to compute residences within walking distance of significant usable public green
- How to compute residential walls with sight of trees
- How to compute the presence of a minimum amount of green
- How to compute the presence of foliage in public spaces
- How to configure a Grid Overlay's legend
- How to configure a Query for an Excel Indicator
- How to configure a Safety Distance Overlay
- How to configure a Template Panel
- How to configure a Weather
- How to configure a default legend for GeoTIFFs on the Geoshare
- How to configure a default legend for GeoTIFFs on the Geoshare (linux)
- How to configure a dynamic infiltration factor for a Water Overlay
- How to configure an Average Overlay to gain insight into grid cell values
- How to configure an intro Cinematic for a Stakeholder and a Scenario
- How to configure bottom boundary flow to vary over time (Water Overlay)
- How to configure constant bottom boundary flow (Water Overlay)
- How to configure more realistic evaporation rates for a Water Overlay
- How to configure the Distance Zone Overlay to count features
- How to configure the Image Overlay
- How to configure the Water Overlays
- How to configure the Waterwijzer Overlay to use groundwater results from other calculations
- How to configure the available actions of a stakeholder per scenario
- How to configure the names of features created by a Geo Plugin
- How to configure two overlays with different settings for hydraulic structures and hydrological features
- How to configure year round calculations
- How to convert a DWG to GeoJSON
- How to convert a Revit model to a SLPK file using ArcGIS Pro
- How to convert a single coordinate from one CRS to another
- How to correct a building at the edge of the project area
- How to correct a building in an uninterrupted waterway
- How to correct a culvert connecting two water level areas
- How to correct inlets on land
- How to correct multiple buildings on the same location
- How to correct weir, pump, or culvert drawn as point
- How to correct your Water Overlay data
- How to couple Cinematics to Stakeholders
- How to create Functions
- How to create a Basic Mode Project
- How to create a Cinematic flythrough
- How to create a Destination area
- How to create a GIF animation
- How to create a GeoJSON file in ArcMap
- How to create a GeoJSON in QGIS
- How to create a GeoShare Viewer
- How to create a GeoShare Viewer with multiple timeframes
- How to create a Geo Plugin for DXF files
- How to create a Geo Plugin to import Areas from the Geo Share at Project creation
- How to create a Geo Plugin to import Buildings at Project creation
- How to create a Geo Plugin to import district in the Netherlands at Project creation
- How to create a Panel for each Item owned by a specific Stakeholder
- How to create a Panel for each of an Item type
- How to create a Panel for some of an Item type
- How to create a Project Source for a WMS
- How to create a Rain area
- How to create a Template Project
- How to create a WFS for data on the GeoShare
- How to create a WMS of a GeoShare Viewer
- How to create a new Project
- How to create a new Project with 3D BAG data
- How to create a panel for each Item visible only to its owner
- How to create a parametric design
- How to create a subdomain
- How to create a traffic density Grid Overlay
- How to create an Average Overlay based on another Grid Overlay
- How to create an Average Overlay based on feature attributes
- How to create an Excel background calculation model
- How to create an HD Movie or Video Recording from the Cinematic
- How to create an Overlay which highlights unused land
- How to create an SLPK file
- How to create an alert Panel
- How to create an area of trees using parametric design
- How to create an evacuation routes overlay
- How to create an interest area GeoJSON
- How to create an overlay for visualizing your own geographical vector information
- How to create an urban area using parametric design
- How to create deviating behavior for a single instance of a Template Panel
- How to create foliage height based on an Inference Overlay
- How to create or remove Cinematics
- How to create prevent the creation of a single instance of a Template Panel
- How to deal with a long processing DXF import
- How to delay Grid Overlay calculations
- How to detect foliage using an Inference Overlay
- How to detect solar panels using an Inference Overlay
- How to download Aerius results
- How to draw selections for buildings
- How to duplicate a traffic unit
- How to duplicate an Area
- How to edit Attributes of multiple components
- How to edit Cinematics
- How to edit Event Bundle events
- How to edit Events
- How to edit Global properties
- How to edit Indicator properties
- How to edit Indicator targets
- How to edit Key Points
- How to edit Neighborhood properties
- How to edit Stakeholder properties
- How to edit Zone properties
- How to edit a Combo Overlay's formula
- How to edit a Net Load
- How to edit a User
- How to edit a WFS link in your project
- How to edit an Attribute
- How to edit an action menu
- How to edit building addresses
- How to edit building properties
- How to edit general measure properties
- How to edit general network settings
- How to edit measure cost details
- How to edit measure events
- How to edit network specific settings
- How to edit properties of a Levee Spatial
- How to edit properties of a Levee Type
- How to edit solar panel position
- How to edit spatial components of a measure
- How to edit the Camera Position
- How to edit the address information of an address
- How to edit the amount of units per hour
- How to edit the attribute information of an address
- How to edit the properties of an Area
- How to edit your project data via WFS
- How to enable the difference option for a Grid Overlay
- How to export a DXF
- How to export a DXF reference file for a project
- How to export a GeoJSON from QGIS
- How to export a Grid Overlay as ASCII
- How to export a Grid Overlay as GeoJSON
- How to export a Grid Overlay as GeoTIFF
- How to export a Grid Overlay as png
- How to export a Grid Overlay to the GeoShare
- How to export an Object output attribute as measurement
- How to export measurements
- How to export objects in a project to a CSV
- How to export objects in a project to a GeoJSON
- How to fill NO DATA values in a grid overlay by interpolation using and Average Overlay
- How to find the ID of specific data in your project
- How to find the Object flow output attribute related to a specific Overlay
- How to fix a GeoTIFF that has an invalid NO DATA value
- How to force Grid Overlays to recalculate
- How to generate a network using the network wizard
- How to generate a sewer
- How to generate an initialized groundwater situation
- How to import 3D BAG data
- How to import 3D Models from ArcGIS Online
- How to import AutoCAD BLOCKS with attributes
- How to import AutoCAD DXF files
- How to import KNMI weather data into Microsoft Excel
- How to import Net Lines using a GeoJSON
- How to import Net Loads using a GeoJSON
- How to import a 3D model in ArcGIS Pro
- How to import a CityGML/CityJSON file
- How to import a CityGML/CityJSON file for 2D Spatial data
- How to import a DWG file in ArcGIS Pro
- How to import a GeoJSON of waterways
- How to import a GeoJSON to change the elevation model
- How to import a GeoTIFF of waterway depths
- How to import a GeoTIFF to change the elevation model
- How to import a SketchUp model in ArcGIS Pro
- How to import a breach with external area
- How to import a breach with input area
- How to import a foliage height GeoTIFF
- How to import a measure with water
- How to import a time sequence for multiple structures
- How to import a time sequence with a CSV
- How to import an ArcGIS SLPK file
- How to import an SLPK file for 2D Spatial data
- How to import and assign a texture in ArcGIS Pro
- How to import data from a WFS
- How to import discharge areas
- How to import features from ArcGIS Online
- How to import features with Attributes from DXF
- How to import foliage height areas
- How to import i3s scene layer in new project
- How to import measurements
- How to import sewer overflows
- How to import sewers
- How to import trees based on an Inference Overlay
- How to improve the estimated foliage overlay
- How to inspect breach output attributes of an overlay using the measurement tool
- How to inspect object output attributes of an overlay using the measurement tool
- How to inspect the contents of a Panel in a web browser
- How to interact with a popup
- How to interact with the Top Bar
- How to investigate flow issues in waterways
- How to investigate increasing water levels in waterways
- How to investigate odd behavior near model edges
- How to link functions to upgrade types
- How to load grid values from a GeoShare WMS
- How to load in dynamic evaporation rate (Water Overlay)
- How to load in dynamic rain and simulation time (Water Overlay)
- How to log in an ArcGIS Enterprise account in the Tygron Client Application
- How to log in an ArcGIS Online account in the Tygron Client Application
- How to log out an ArcGIS account in the Tygron Client Application
- How to make a Grid Overlay of residence walls
- How to make a Grid Overlay of residences
- How to make a Project accessible for Tygron Support
- How to make a line measurement
- How to make a point measurement
- How to make an Indicator visible to only one stakeholder
Pages in category "How-to's"
The following 200 pages are in this category, out of 457 total.
(previous page) (next page)C
H
- Health (Indicator)
- Heat Reduction (Indicator)
- Heat risk (Indicator)
- Housing target (Indicator)
- How to add a User
